weil-mclain out side temp
goat
Member Posts: 6
in Gas Heating
I have a weil- mclain ultra 105. I had to disconnect the outside temp sensor because the unit wouldn't turn on . Screen says outdoor temp none. Have checked all wires with a ohm meter and all is good any advice?
ohm
Did you ohm out the resistor also? I believe they give a list in the manual as to resistance in comparison to temp, is it in the area?0 -
outside temp
Thanks I'll try that tomorrow0 -
Sensor
When sensor fails boiler shuts down. You would think there would be a default temp so you dont freeze.0 -
temp sensor
Replaced outdoor temp sensor and reset system. It's all good Thanks to you all !!0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
