Heat loss question
TonyS
Member Posts: 849
What temperature difference are you using for a semi detached partition wall?
I use to use a 2 degree loss figuring the neighbors might keep their stat down a little but now a lot of the homes are empty and winterized. Opinions?
I wouldn't increase capacity based on that...
That is not a "normal" operating consideration. Besides, it has been my experience that even on jobs that I know for a fact were properly sized, when I show up at design condition, the system is doing a 50% duty cycle, which tells me it is two times bigger than need be.
METhere was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
