old boiler, new vent
annieh
Member Posts: 1
in Gas Heating
I have an older ( 20 years maybe ? )Utica Boiler that I need to pull the vent out of the chimney , along with the hot water heater vent and re vent them elsewhere. Is it possible to power vent these through a sidewall?
Thank you.
Thank you.
New vents:
Surre. You can power vent them through a sidewall. But they must be separate and individual. You can't have one power venter for two appliances.0 -
Why
do you have to do this? If the chimney just needs a liner, it's far less complicated to have one installed..................All Steamed Up, Inc.
Consulting0 -
Sidewall vent
You can sidewall vent a gas appliance if, it was previously certified as sidewall vented. You cannot legaly and whitout liability, sidewall an appliance that was not certified for sidewall venting. You cannot vent two appliances in the same sidewall vent, legaly!
Yes S/S chimney liners are cheaper to solve a chimney issue, in most cases.
Please find yourself a reputable and licensed contractor to propose the right solution with no fatal effects by monking around with venting!0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
