steam radiator replacement
Doug_45
Member Posts: 6
I'm going to salvage yard to replace a leaking steam radiator. How can I pressure test to check it. Any special equipment or technique? Any tips on what I should be looking for?
difficult?
You would need to put a reducer in the supply (or if 2 pipe either supply or return), and then have an accumulator pump with an accurate gauge, or a compressor with a regulator on it that will measure in ounces. Then couple the source of air to the reducer (if 2 pipe, seal the other end) slowly apply the air, and spray with a leak detector solution, ie. dish soap diluted with a good bit of water. Where it bubbles it is leaking. I would check for a minimum of 2 psi, but since the safety check valve of the boiler is set to blow at 15 psi, a pro might want to see it tested up to that range.steam newbie0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
