Maximum Length of exhaust exposed to cold for Buderus GB142
kgssully
Member Posts: 5
in Gas Heating
Hi Guys,
Trying to find the info for the maximum length of exhaust pipe that can be exposed to the cold(in MA) before I have to worry about freezing. Having trouble meeting the 4ft from window requirement and would need to run about another foot or two outside away from window to meet this spec. Any ideas? Thanks a lot. Great website!!
Uninsulated vent specs
The manufacturer should provide the specs; but since you're asking the question, I'll assume they don't.
The attached specs are from Carrier/Bryant spec sheet on a 94% efficient furnace with a PVC vent system, so flue temps are likely similar. A single wall stainless vent system would merit a little more conservative approach. The last 3 digits in the unit size is the BTU inputs (the 042060 is a 60 000 BTU input furnace.)
I hope this helps.There was an error rendering this rich post.
Thanks
Perfect. Thank you. I couldn't find anything like this in the Buderus manual!0 -
Here is What You're Looking For
It's one their tech bulletins. It's on their web site.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
