Looking For Honeywell T-stat Install Man
The Steam Whisperer (Formerly Boilerpro)
Member Posts: 834
I checked thier comsumer website and it appears to only have the user manuals. I believe its a model TH 6000
Thanks....
I think that's the one I need. Where can I find this type of info in the future?There was an error rendering this rich post.
Finding Honeywell Manuals
Actually I had this manual already as I had downloaded it several months ago when I was comparing features of different Honeywell Thermostats.
Searching for information on Honeywell products can be rather confusing as you usually have to poke about a bit to find what you want. Here is the Honeywell's website for manuals and other info.
Honeywell Website: http://customer.honeywell.com/Business/Cultures/en-US/Default.htm
On the webpage above, go to the lower right corner you will see red block labeled “Literature/Image Search”
In the upper window, select “All Files” and in the Lower Window select “Model/Part Number” and enter the model number of the unit you are looking for information about. Click the red button with the white arrow next to the bottom window to start the search
The file listing will appear lower down the page. Using the “All Files” term should get you the manuals including the installation manual. The other selections seem to be oriented to providing just “homeowner” information.
- Rod0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
