pictures
Slimpickins
Member Posts: 339
I was going thru some pics I took last winter and this one cracked me up. They probably needed 6" of fin tube in the entry, LOL BTW, whatever happened to the Hall of Shame?
Aahhhh...
...isn't that cute!
Shhh....you might wake it up!All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
yes but
"whispering" is it on it's own zone?0 -
thank god
the baffle is open.....or you may not get any heat out of it....steve0 -
Freezing
Those 10 fins are begging to be frozen & busted by a door left open on a below freezing winter day.:NYplumber:0 -
Small Stuff
That reminds me of the 2 section radiator I saw at a job in a bath recently. Cute!0 -
If...
I had not seen it, I would not have believed it. What was the installer thinking? There was as much labor (maybe more) installing that as there would have been installing two 8 ft. sections and an inside corner. And for what? Maybe 500 btu's output?Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
