return,filter,comfort air blower,coil and supply trunk
Celona
Member Posts: 1
That is how every central a.c. unit I ever saw was.How come my coil is before my comfort air blower and I am going to assume that is why my thermostat will not satisfy.Has anybody ever see an a.c. unit set up that way that works correctly before I confront my landlord.Thanks in advance!
Evap coil
Not unusual and sometimes it is where it is due to limited space. You will also notice that the condensate is trapped or should be trapped because of the neg. draw. The only problem is the filter. Should be doing its job before the A/C coil.
Mike T.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
