sand hole
World Plumber
Member Posts: 389
I have an elderly lady with a steam boiler approximately 20 years old. Has a drip from the center section looks like a sand hole. I remember when I was young the old timers using boiler seal. Does anyone know could this be a lasting repair?
If not is it feasible to replace a section on something that old?
JB Weld ?
Being a homeowner I have no experience with boiler seal how ever you might consider using JB Weld which is a high temperature epoxy available at most auto stores. It's rather "Mickey Mouse" but might be worth a try. Grind/ scratch a bit to get to bare metal.
- Rod0 -
leaking steamer
there are lots of commercial boiler sealers out there and it may be worth a try....as a temporary fix. JB Weld is also just a patch job and there is no really good or safe way to permanently patch a boiler....As to replacing sections.....depends on what kind of boiler and if the sections and nipples/gaskets are still available....good luck0 -
As said all repairs would be temporary.
Do yourself and the lady a favor and replace the boiler. If she is short on funds there are places that can help her finance or even give her grant money. Where is it located? Someone may have a more specific place to ask for help for her.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
