Burnham Alpine
Anthony Possidento
Member Posts: 7
Has anyone installed or familiar with Burnhams Alpine condensing gas boilers? I am bidding ajob with the 399btu Alpine. It's oil to gas conversion instead of lining the chimney I've got room to exhaust it. Any input would be great! thanks
Alpine
We have about 2 dozen in the field running fine. The sage 2 control is nice! One thing to look for is when wireing it make sure the wire to the ignitor dose not lay against any of the low voltage wires running around inside, happens when you pull out the board to wire it and tugs on the ignition wire. Had a few hard lock-outs because of that (I think there is an updated ignition wire now).0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
