Voyager combustion blower
Leebbear
Member Posts: 1
in Gas Heating
How do you troubleshoot/check a combustion blower on the Voyager SSVH90 45SA heat exchanger?
Trane RTU? Voyager?
If so the Induced draft motor is shorted out. Will still work in heat, but not shut down. Trane is well aware of this problem and was , for a time covered under warranty.
Mike T.
PS; Hi Tim..........0 -
Hi Mike
how are you doing?0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
