quick but important question
Maestro232
Member Posts: 69
Hello...something seems amiss after a boiler guy came into my house to scope what he needs to re-pipe my system (since he did it wrong). I'm pretty sure he cranked a thermostat on my system but you guys would know for sure. It's a tankless coil in an oil fired steam boiler and domestic water comes from a storage tank through the coil and heats up, then goes back to the tank. I'm almost sure I was told the boiler should maintain a water temperature about 20 degrees higher than I have the hot water set. Well, I had the hot water set at 115 degrees, and I thought the thermostat off the tankless coil was set to around 135 degrees. Well, after this guy showed up I noticed the water was scalding in the house all the sudden. I checked the boiler thermostat and it was set to 175. Am I crazy, or is that way too high a temperature for the boiler to maintain?
Water to hot!
It sounds like you may need a mixing valve?0 -
I don't understand...
I don't understand. What I'm wondering is if I'm losing my memory or not. I thought the thermostat for the boiler was set to maintain about 135 degrees because I have my hot water set to about 115. I'm wondering if that ratio is correct because it is set to 175 not 135, and I recall that it should only be about 20 degrees higher.0 -
as Alan said, but
If I understand your post, you have an aquabank? The thermostat on the tank is what will control your water temp for domestic . When you are making steam for heat, it is hotter than 175. The temp that you should maintain should be at least 20 degrees warmer than your desired storage temp, and I think that is what you are talking about.0 -
That's it exactly...
Yes, you've got it exactly. It's an aqua bank. Ok, so I am remembering correctly. I had reason to believe the boiler guy might have done this maliciously, but I just couldn't remember for sure that it was supposed to be around 20 degrees higher.0 -
If your
domestic hot water temp has changed, then he may have turned the thermostat up for that to test something?0 -
just curious
as to what he is re-piping, what he did wrong, and is it a heat or hot water issue that has him doing what he should have done right the first time?0 -
It's a long story...
But if you really want to know...
http://www.heatinghelp.com/forum-thread/135799/Recourse-for-bad-illegal-boiler-install#p12268280 -
oh ok
Now I remember. VERY long thread. Good luck to you on that0 -
haventseenenough
r u still beating this horse?0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
