Raupanel
Big Will
Member Posts: 396
The numbers sound great. Its expensive but few good products come cheep. My vendor has been talking it up for a while. The only thing that concerns me is noise. I am worried about the aluminum expanding a lot and making noise. Also the floor contact is only the edges of the aluminum plates and the little aluminum runner. This seems like it might flex and also make noise. Just looking for some feed back. Thanks
it's a very high performance product
but we have seen noise in some installations. My gut suspicion is that it was installed paralell with the floor joists and the give in the subfloor caused it to rub. but I can't prove it.
there are many with noiseless installations out there so I'm not saying the product is bad. Just that it requires more thought in the install, apparently.Rob Brown
Small Job
We just finished a 200 square foot project where I wanted to use QuikTrak, but my supplier was out of some of the panels. They had plenty of Raupanel and we used it instead and were pleased with the way it turned out - a quiet floor with no flex.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
