adding more heat to living room
nycpa
Member Posts: 108
I have a traditional stream heating system. Works fine so far. I wanted to add heating to my finished basement as well as more heat into my living room because the radiator present is more like a bedroom radiator than a larger living room radiator. In order to install a larger radiator, I would have to break the wall, remove studs and restud and sheet rock it since the radiator is built into the wall. I wanted to add a baseboard to the living room since its one consists of making two holes through my wall. Do you guys think it would be a problem to have the living room baseboards and basement baseboard as one loop? Also, would I be able to control the two as separate zones or will they be one zone as a whole? How does the idea sound of getting more heat into the living room?
I would be inclined...
to run the basement as a hydronic loop off the boiler -- several ways to do that. Assuming you have the capacity. You could either run hydronic baseboard in the living room (but I'd make it a separate loop -- unless you are real lucky, you won't want the same amount of heat in the living room as the basement!) or put in a bigger steam radiator -- and there seems to me the decision would be largely how much hassle is which option.Br. Jamie, osb
built into the wall?
is it a convector of some sort? or a cast iron rad that is recessed? do you have a picture? are there drapes or furniture restricting airflow? has it been vacuumed out recently? if it's a convector of sorts, it may not be putting out enough heat due to lack of convection and not necessarily be undersized. picture would help, so may shorter drapes.1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
