Industrial Boilers?
SpeyFitter
Member Posts: 422
in Gas Heating
I'm just curious if there are any industrial/heavy commercial gas fitters in here? Anyoen work on the big fire tubes or water tube boilers? (you know, when things start getting rated in boiler horsepower instead of BTU's).
Class 'A' Gas Fitter - Certified Hydronic Systems Designer - Journeyman Plumber
Big steam
No problem, we do both commercial heating applications and process from 10HP to 1,000HP.
Henry0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
