Undersized Boiler? Make two Zones?
Chuck_36
Member Posts: 42
in Gas Heating
Hi Man,
Taking advice and experimenting with my second floor system, it has four shut offs on two main branches. I shut half the distribution and he was right, the boiler temp and supply ran up to a normal range (145F-155F) for the very first time in my history with this conversion. The supply remined low. Absolutely, the system works best on half the water. I could split the apartment into two zones. I don't want to spend for larger boilers. These are only two seasons old. Woud you try anything else?
As we have a history, You know my low boiler and radiatior temp problem. I finally have a workable premise for a possible solution !
Not quite sure what
you are asking?0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
