ITT Nesbitt ptact
keith_27
Member Posts: 64
in Gas Heating
Looked at a nesbitt n15-58 wall heater today. The fan motor is faulty. After checking the unit how would i acess the motor and wheels ?
I am not familiar with
that unit but most wall furnaces have the blower in the top of the unit and it blows down over the heat exchanger. Some pictures would help.0 -
Most wall furnaces
On most wall furnaces, the blower assembly is easily removed with a couiple of screws and disconnecting the wires or plug. Fan, shroud and wheel or blade as an assembly.
Minnesota Wayne0 -
NESBITT
I supply all NESBITT OEM parts. Let me look into this and see if I can find some O&M literature for you.
If you need parts shoot me an e-mail.0 -
NESBITT
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
