snow melting
MikeJ
Member Posts: 103
Installing a 800 sq. Ft. patio, Installing 3/4" pex 12 inch centers. what are some ways to turn the system on and off automatically with out spending a lot or is there.
Thanks
Thanks
Automatic Control
If you want automatic control, you'll either spend it for a good control or you'll spend it on fuel.Bob Boan
Spend Alot Now or Later
Spending alot on a control now will save you in the long run. I like the tekmar 665 with in slab sensor. It gives you lots of options and along with a 265 will give you outdoor reset for your boiler also.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
