Glycol -Seals and o-ring deterioration
Hans19
Member Posts: 1
Hydronic System -gas boilers (500,000 Btu)-base board registers.
Are their reports of any of the major brands of anti-freeze causing deterioration problems with circulating pump seals, o-rings in propress fittings and or system gaskets?
Pump seals....
We haven't had issues with o-rings / gaskets, but have found that Ethylene Glycol (Dowtherm) doesn't get along well with the zinc plating in circulators. More specifically, B&G PL circs, where the seal fits into a recess in a plate, we get corrosion and a leak. Hope this helps...0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
