zoning second loop
css
Member Posts: 1
in Gas Heating
Hi, new to forum. I have a Weil Mclain cga-4 boiler running a single series loop baseboard heating system. I am in the process of installing a second zone. I will be using circulators as opposed to zone valves. I have done all the heat loss calculations and know that the boiler will be fine(in size). My problem is that I am having a heck of a time figuring out the wiring side of the install(this is usually one of my strong points). I just cant seem to understand how to wire the t-stat, new pump, and boiler together with the current installed pump and tstat. I understand the tstat will be wired to the new pump controll relay to turn the pump on but from there I cant figure out how to make the boiler fire. Any help/advice would be appriciated. The simpler the explanation the better. Thanks in advance
Chad S
Chad S
RA832A Switching Relay
If you use an RA832A, you will wire the pump as usual, run the thermostat to T+T, and wire the boiler circuit to the dry contacts X+X for a 24 volt burner, or the number 4 (I think it;s 4) contact for a 120 volt burner.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
