What do you put behind cast iron baseboard radiators?
howdiho
howdiho Member Posts: 2
Hi, I am so glad to have found this site.
I am refinishing my basement and I have cast iron baseboard radiators (about 20 ft long) in one of the rooms that is a walk out. The wall that it will be against is concrete with studs in between.
So my 1st question is... what do I use to reflect the heat back into the room and where do I put it? I was told by one person to nail aluminum flashing BEHIND the drywall...but that doesn't seem right.
The 2nd question is...do I put insulation behind the radiator/drywall?
Thanks in advance for the advice, Matt
  • howdihi
    howdihi Member Posts: 1
    Doesn't anyone know the answer to this?
  • Unknown
    edited August 2010
    I have just,
    insulated the studded wall as usual, then drywall & used regular kitchen foil-wrap(shiny-side facing out) sandwiched between the rad and the new drywall.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,322
    Sorry never answer earlier
    Nothing. I just make sure the wall is well sealed along the floor with caulking of your preference to keep out drafts.
    cell # 413-841-6726
  • howdihihi
    howdihihi Member Posts: 3
    hi
    I don't know why but this is the third time I have created an account with a new e-mail to post here. It keeps saying my e-mail and password is incorrect, which I know is not.
  • howdihihi
    hi
    Thanks for the idea, I would never have thought of that
  • howdihihi
    hi
    So, you do not put insulation behind it or you don't use reflective material?
  • Unknown
    edited August 2010
    Not sure,
    what make of CIBB you have, but this is the W/M procedure. Aluminum foil does the same-thing.
    http://www.weil-mclain.com/en/multimedia-library/pdf/weil-mclain-pdf/products/baseboards/snug-baseboard/snug_baseboard_install.pdf
    PS- Yes, insulate the stud cavity behind, remember "heat goes to cold", you want to drive it into the room, not the outside wall. ;-)
    wall needs to be insulated.
    I do not use the aluminum foil. My way off looking at it is the conductive properties of the foil are out weighed by the reflective powers. The reason we use aluminum plates in radiant heating systems is to transfer the heat to the surface it is touching. White paint and a good draft sealant will do more good so you can do as Dave says and have a good job or do as I do and have a good job. It is up to you.
    cell # 413-841-6726
    joehenderson1987
  • Dobee
    Dobee Member Posts: 1
    reflective material behind iron radiators
    Most everyone has a good point to make; however, for years I've been using a combination of "tru-foam" "dense Styrofoam" and aluminum foil.  The foil will help to reflect most of the radiant heat back toward the room.  Foil will not reflect all the radiant energy but reflect a significant amount.  To minimize the conductive properties of the metal, especially aluminum, spray glue a single layer of foil to the dense foam.  The square of foam only has to be the size of the iron sections that radiate the heat.
    For cleaning purposes and to create an additional small air gap (about 1/8 to 1/4 inch) between the wall and the foiled foam to further minimize unwanted conduction into the wall , I glued Velcro to the back of the panels and attached the other "Velcro receiver" piece to the wall.  This allows me to easily remove them for cleaning or to remove them for summer months.  Use a good quality spray contact cement that has low odor (like the brand name: Stay Put or Sta' Put or whatever...).  The hard foam only has to be 1/2" to 1" thick.
    Doing this will reasonably minimize unwanted conductive properties of the metal and maximize the reflection of heat radiation.
