Circulator pump starting to fail.
Sweet_Lew
Member Posts: 116
Good Evening All,
Tonight I started to hear a weird noise eminating from the radiators. I went down to the basement and heard the noise coming from the heating system (Hot water boiler). It was the circulator pump making a slight grinding noise. How concerned should I be in replacing it? I'm trying to hold out just 2-3 weeks more until the nights here in Chicagoland get a wee warmer and I can turn off the system until next fall.
The pump is a Taco 007-F5, so I'm sure the cartridge is going so I could swap that out, maybe upgrade to a better pump (I've read Taco, Grundfos, and B&G are the more popular makers). Anyone recommend a different pump? Here's my system details:
Boiler: Bryant Legacy BW-2
Pump: Taco 007-F5
Aquastat: Honeywell L8148E
System is in the basement. I have 4 large rads on the main floor and 4 smaller rads upstairs. Total heating area: 1500 square feet.
Thanks for reading.
Pump: Taco 007-F5
Thanks for reading.
Update
Probably going to change out the pump sooner than later. Looking into Grundfos (their new Alpha looks pretty slick) and Wilo pumps.0 -
Especially if this is a converted gravity system
you'll want to measure the square feet of radiation (EDR) rather than the square feet of floor area. Then go here for sizing info:
http://www.heatinghelp.com/article/11/Hot-Tech-Tips/238/Sizing-Circulators-for-Hot-Water-Heating-SystemsAll Steamed Up, Inc.
Consulting0
- 86.8K THE MAIN WALL
- 56 Biomass
- 107 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 954 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
