new boiler
d1961
Member Posts: 2
am getting ready to replace my 94 year old boiler. i have the book the lost art of steam heating, in doing my research i have discovered i have the "dunham home heating system" as illustrated on page 252 figure 23. my current system does not have a hartford loop. (again like the illustration). my question is do i need to eliminate the 1/4" dunham air line valve which is indicated by the number 3 on illustration? and if i need to keep them are there any moving parts inside that i would need to update or replace?? as i will be adding the hartford loop upon completion.
thanks
thanks
Do you have a picture handy. My copy of The Lost Art is in my work van.0 -
see pic
here is a picture of the existing valve, it is at the end of the main steam run before it goes back to the condensate, i do not have a scanner. i have included a couple more that may help reference it for you0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
