Mega Steam Header Question
Eric Olson
Member Posts: 9
Is it acceptable to use 2" black pipe rising from a new Burnham Mega Steam Boiler or is it far better to use 3"? Thank you in advance for the info!
WWBD?
what would burnam do? the installation is probably pretty specific about the pipe sizes, and number of risers for a given boiler, in order to have the driest steam possible. bear in mind, that this is a minimum configuration [do a search for "dropped header" here on the wall].--nbc
[url=http://www.heatinghelp.com/forum-thread/129890/Drop-Header-What-are-you-kidding]http://www.heatinghelp.com/forum-thread/129890/Drop-Header-What-are-you-kidding0 -
picture of my megasteam proposed header
Eric --
in the link which NBC posted above is a picture of the header I'm proposing for my new megasteam .. it will rise a few inches in 2" (that's what the MST tappings are) and then open up into 4" for the fittings you see... you can see all my evolutionary pictures along with some comments in this post: http://www.heatinghelp.com/forum-thread/129767/megasteam-396-header-mockup1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
great comments
Thanks for the comments guys, I guys I am in the air as to whether 3" is big enough or if I should increase to 4". What compound or tape do most people use to join the pipe together?
Eric0 -
the dope on dope
here's an entire thread about dope.
http://www.heatinghelp.com/forum-thread/129580/The-best-pipe-dope
i also think that steamhead and others may have chimed in once or twice before in other random threads ... like here: http://www.heatinghelp.com/forum-thread/129005/Assembly-Question#p11839511-pipe Homeowner - Queens, NYC
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
