End of main vent of some sort part #20-1885
dead
Member Posts: 1
Harvard Medical School old steam system partialy converted to hot water has 3 air vents?part #20-1885 pat.june 1863(thats all info I could get off them)looks to be installed upside down and piped together they have 3/4 pipe running to each one seperatly installed in top of building 20 feet above all piping.one is hot the other two are cold.Before I tear the walls apart and trace back piping I would like to know exactly what they are.I need more info on system and am working on that.
a picture is worth a thousand words!
some pictures [even cel-phone pics] would help one of the very old timers here recognize this vent. as i presume this is on the steam side of the system, it should not be difficult to find a replacement. what are the symptoms which prompted your visit?
when you say the system has been partially converted to hot water, is that with a hot water loopf the boiler?--nbc0 -
have a look at...
the pictures in the following PDFs perhaps you'll see the thing you seek...
1901 - Practical Treatise upon Steam Heating..... - http://books.google.com/books?id=UggKAAAAIAAJ
1903 - Modern Plumbing & Steam Heating .... http://books.google.com/books?id=7tVAAAAAIAAJ (starting around PDF pg 220)1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
