Equalizer valve
Luv'nsteam
Member Posts: 278
With king valves on both mains closed and a return valve in the Hartford loop, also closed, then open up mud leg/return condensate valve (at rear of boiler) and mud leg can be blown down. This is described in Dan's new book, <span style="text-decoration:underline;">Greening Steam </span>(page 102).
I was thinking though, what if there was an additional valve, located in the equalizer? Close the equalizer valve, king valves and the return valve. Open up the boiler mud leg blow-down valve with steam cranked up for cleaning and the steam, not being able to travel through the header into the mains or equalizer or Hartford loop, would clean out the bottom of the boiler. Does this make sense? Do you who are wise and knowledgeable think this a good idea or not? Please advise.
Thank you,
Mike
Thank you,
Mike
after studying...
after reading Dan's blowdown procedures, asking questions and studying different pictures installed by the pros .. I installed several "return-side" valves .. see 3 pictures starting here: http://picasaweb.google.com/jpf321/Fitzgibbons400Boiler?authkey=Gv1sRgCNOPnfifvI7MNA#5420443420370978322
I have a boiler drain valve in background of 3rd pic, a dirt leg drain, a gate valve on hartford and a return drain right after glass pipe .. i sould be able to blow most things with these valves installed.
jpf1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
pics of valves
JPF, nice pics. I especially like the glass return. What a great way to keep an eye on the water quality.
I have no doubt if I do not use the equalizer valve I will still be able to blow down and clean the boiler, but if the steam can only force the water backwards though the boiler, I was just thinking it would be a more efficiant cleanout of the bottom.
How do you paste the words on your pics?
Thank you,
Mike0 -
i use Picasa...
i use http://picasa.google.com/ from google for all my local picture management .. it allows me to add text ... what's even nicer is that it allows me to change the text at a later date if I like .. that is, the text is not permanently embedded .. i love picasa .. and of course if I have "sync to web turned on" any changes which I make locally are reflected in my online albums.
Picasa
I'll check that out, thanks JPF.
Mike0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
