boiler in a vacum
anthony_12
Member Posts: 9
TRUE OR FALSE "A STEAM BOILER IN A VACUUM IS NOT A GOOD THING"[NO VACUUM PUMP IS INVOLVED}
vacuum question
when steam condenses, it develops a vacuum. this usually at the end of a burner cycle, and will persist until the main vents have let the air back into the pies, rads, and boiler steam chest.
if you are seeing a vacuum at other times, then you may have:
1. a vacuum system, or
2. a plugged pigtail/faulty gauge.--nbc0 -
Generally speaking,
false. What harm is it going to do? In fact, some steam systems in the old days deliberately ran a vacuum at some points in the cycle.
As NBC notes, though, nowadays the vacuum shouldn't be very deep, nor last very long. Not because it is bad for the boiler -- it isn't -- but it usually indicates a problem somewhere else in the system. Unless... you have a system intended to run that way, and they are out there.Br. Jamie, osb
Maybe yes, maybe no
A steam boiler that runs a vacuum in a system not designed for vacuum risks sucking make-up water in through the check valve, producing a flooded boiler. I've seen this happen in two-pipe systems with zone valves that shut off all the mains when there is no call for heat. The fix is to install a vacuum breaker above the water line to relieve the vacuum.
One-pipe systems with main and radiator vents should never run a vacuum.
See "The Lost Art" for details on vacuum systems.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
