noises boiler
TG153
Member Posts: 1
having trouble with my boiler its a h.b.smith model#g100-w-5 cond.
it sound as if the water is boiling in the boiler. I have drain the system twice to remove any air. I have check the expandtion tank and have 12psi.
The pressor relief vavle is not leaking. can anyone help?.
May be the circulator is not running
It may also have build up in the boiler restricting flow. Find a pro and have them look it over.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
