leaking gorton #2's
STEAM DOCTOR
Member Posts: 1,973
i did two jobs recently where i used #2's on the longer main and either a Hoffman 75 or gorton#1 on the short main. on both jobs the #2's emitted steam/water vapor while the other vents functioned properly.this was after 4 out of 6 #2's failed the blow test out of the box. I've read a number of posts on this site about leaking #2's. i think that we have to draw the obvious conclusion that there is something wrong with the #2's. from here on in there will be no more #2's for me. i will probably stock up on the #1's and put in 3 or 4 in place of every #2. i know this involves more work but i really do not have the time to do every main vent job twice.
PS if Toyota can have such serious production problems there is no reason to think that it cant happen to gorton. i do very much hope that someone from gorton reads this site and addresses this issue.
Keep an eye on this thread
I just ordered 2 gorton #2`s from Pex supply. They are on back-order. As soon as they arrive at my door I am going to install them. If they leak, I will be returning them to pex and getting a refund.
I will post my G2 experience here when I get them.73 year old one pipe system with original American standard boiler, oil fired becket, 2 inch steel pipe main, 100 feet long, with 8 radiators above.0 -
do the blow test
when u get them hold them upright and try to blow through. u should be able to blow with ease. then turn them upside down and blow again. you should not be able to blow at all. best of luck0 -
valves
is that how you can test all your valves0 -
yes
its not foolproof but if it fails the blow test then you know that the valve is no good. its possible to pass the blow test and still not function properly0 -
test rig ;-)
Very high tech test rig. Hey. Its Friday. Gimme a break!
-Terryterry0 -
vertical?
shouldn't the vent be vertical to work properly?
nice idea though.There was an error rendering this rich post.
Can't build much pressure in a teakettle anyway, but
I use it to confirm closure with steam temperatures. The upside down test still checks for a full seal. Hoffmans will still pop closed. BTW, just use an inch of water so you can tilt it to a vertical position if desired.
Be aware, however, that best practices suggest the use of proper safety equipment as pictured below.
Given this decidedly low pressure vessel's low marginal utility for vent testing, it finds it's best use in other applications. Tea Time!
-Terryterry0 -
Just in case
My gorton #2`s are still on back-order from Pex Supply
When I get them I will be performing the blow test
Just in case they fail this test, HOW MANY HOFFMAN 75`s will I need to get to equal the two G2`s??73 year old one pipe system with original American standard boiler, oil fired becket, 2 inch steel pipe main, 100 feet long, with 8 radiators above.0 -
Blow test
When you invert the vent and blow into it gravity in pushing the float into the valve seat. When installed the steam heats the bi-metal strip it expands pushing the float into the valve seat. So it is very possible for it to pass the blow test and fail under steam.0 -
blow test
I understand that the brand new G2`s could pass the blow test and still not work properly when installed
I will check with Pex Supply and find out the return policy for a G2 that has been installed.
I would still like to know how many hoffman 75`s I will need to make up the venting capacity of the two gorton 2`s ??73 year old one pipe system with original American standard boiler, oil fired becket, 2 inch steel pipe main, 100 feet long, with 8 radiators above.0 -
H75s
When both are working as intended, two Hoffman 75s are about equal to one Gorton #2.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
