angle radiator valves
Al Letellier_21
Member Posts: 402
Gentlemen, please help this old steamhead find some adjustable angle radiator valves for an old two pipe system. Need 3/4" valves. I know there is a supplier oft mentioned here but I can't find it in my files.
Would appreciate any help.
AL
AL
supply valves or air vents?
inlet supply valves or radiator air vents?1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
Valve suppliers
Here are two sites I have:
http://www.hammondvalve.com/product_result.asp On left side menu, choose "Plumbing And Heating Valves", then choose "Search Product By Type" and choose "Plumbing and Heating Valves".
Here is a valve from Pex Supply another member provided:
http://www.pexsupply.com/Matco-Norca-BARVY-1250-1-1-4-FIP-x-Male-Union-Steam-Angle-Radiator-Valve-4649000-p
Good luck,
Mike0 -
Radiator Valves
Hi Al - Do your radiator valves with adjustable orifices? Attached is info sheets on two Mepco models.
- Rod0 -
angle valves
Looking for angle inlet valves, high on the rad and trying to match existing.....futile attempt but not asking is an automatic no...these are the old type with elongated handle and a pointer to show position. Trying to get manuf. info in case someone has some old ones around. Certainly the Hammond or B&G will work, but not very pleasing to the eye to my customer.....
thanks0 -
"Pretty" valves
If you find'em, I may be interested in them too. Gotta keep the momma happy whenever/however possible. : )
Thanks,
Mike
no website pics .. but maybe here?
maybe here?
[url=http://www.antiqueplumbingandradiators.com/]http://www.antiqueplumbingandradiators.com/
wow .. a google search for "antique radiator valve" really turns up some beautiful hardware from Europe .. http://www.google.com/search?q=antique+radiator+valve1-pipe Homeowner - Queens, NYC
Cool rads and valves
JPF,
Thanks for the sites. Both offer really beautiful radiators and the UK site has some very cool finishes on the valves. You better really want them, though, they are not priced for the faint of wallet. lol
Thank you,
Mike0
- 85.2K THE MAIN WALL
- 55 Biomass
- 69 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
