High Eff. Gas Storage Type Water Heater
davefordham
Member Posts: 1
in Gas Heating
Any ideas on what is available in residential high efficiency water heaters that would be rated at 94% or better? We can get government cash ($750) for installing one, but the only model I found so far was from A.O. Smith. Thanks all.
what are you needs?
Do you need the tank? Navien has a tankless that is 98% and you get the $1500 back. I suppose if you needed the tank you could add it as a booster....kpc0 -
Hi efficiency gas storage water heater
Take a look at the Hamilton Engineering Companion they can achieve some nice efficiencies and they are easier to work on if need be. Its kind of a Hybrid system between tank style and boilers with a storage tank.0 -
I don't believe
There are any storage type residential gas water heaters that meet the requirement for the federal tax credit. The tax credit also isn't $1,500.00. It's upto $1,500. The credit is 30% of the job to include labor. Your job would have to cost $5,000 to get the full credit. You should be looking at instantaneous gas water heaters such as Rinnia, Noritz, Navien etc."The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."0 -
Federal Tax Credit
Can you post a link to the federal tax credits you are referring to. Thanks0 -
Federal Tax Credit Information
Here is the link. As I stated there are NO residential tank type water heaters that meet the standard for the tax credit.
[url=http://energystar.custhelp.com/cgi-bin/energystar.cfg/php/enduser/std_adp.php?p_faqid=6494&p_created=1254235451&p_sid=r*oTJ9Jj&p_accessibility=0&p_redirect=&p_lva=6496&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MSwxJnBfcHJvZHM9MCZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9NjQ5NA**&p_li=&p_topview=1]http://energystar.custhelp.com/cgi-bin/energystar.cfg/php/enduser/std_adp.php?p_faqid=6494&p_created=1254235451&p_sid=r*oTJ9Jj&p_accessibility=0&p_redirect=&p_lva=6496&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MSwxJnBfcHJvZHM9MCZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9NjQ5NA**&p_li=&p_topview=1"The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."0 -
Electric, not gas will meet requirements
I know its not a gas heater but the new Rheem heat-pump water heater meets the tax credit requirements."If you don't like change, your going to like irrelevance even less"0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
