Difference between Honeywell Vaporstat L408J
derwood50
Member Posts: 10
Hi,
You guys have given me great advice about a problem w/ my home's boiler not getting the return water back into the boiler fast enough. I am reading the lost art of steam heating, and taking the advice I've read here--I want to replace my Honewell Pressuretrol with a Honeywell Vaporstat--but I am not clear on the operating range I should buy--the L408J1009 indicates a range of 0-16oz, while the L408J1017 indicates a range of 0-4psi.
I want the boiler to cutoff at no more than than 2 psi --and possibly less, depending on how low I can adjust it and still get steam in the system--can you advise me which of the 2 models is more appropriate for such an application?
408J Vaporstat
It depends on what type of system you have. It you have a vapor system then you should probably go with the 0 -16oz. I have a crude 1 pipe system so I use the 0 - 4 PSI unit.
When installing the Vaporstat, keep your old Pressuretrol hooked up and set it up as a high limit safety. I 've attached some more info on Vaporstats which might be of help to you.
You also might want to read this thread on vaporstats- especially about Gerry Gill's vaporstat tester - Rod
http://www.heatinghelp.com/forum-thread/128249/why-do-Honeywell-vaporstats-suck-so-badly0 -
Vapor System vs One Pipe System
Are all one-pipe steam systems not vapor systems? What differentiates a vapor system from a one-pipe steam system?0 -
Vapor System
My understanding is that vapor/vacuum systems are almost always two pipe systems and are specifically designed to run at very low pressure. The Paul System, being a one pipe system from the condensate standpoint, is an exception to this.
- Rod0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
