dresser coupling on wet return?
jpf321
Member Posts: 1,568
Rather than figure out how to thread the return at the floor, I'm considering using 2 "dresser universal 90" couplings on a section of my 1-1/4" wet return (for a year or so, until I can repipe and upgrade) ...does anyone have any comments regarding their use? are the "universal type 90" rated for the wet return temps? the dresser website is down so I can't get to the specs right now.
thanks
thanks
1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics
You may find you need to go back to a fitting
They may work on a wet return but would it not be better to go back to the next fitting and simply be done with it? They have stainless clamps for temporary repairs of holes. Once you cut out a small piece you may find you need to keep going to get solid pipe.Cost is what you spend , value is what you get.
cell # 413-841-6726
thanks charlie ...
i'm a bit hesitant to attempt to "crack" a fitting .. these seem less "invasive"...i understand that i may have to back to a fitting if the pipe isn't solid...as long as there are no significant reservations about them failing due to heat or that dresser coupling are crappy .. but only "it may not work" thoughts due to old pipes, the dresser couplings will be my first option .. i will prepare myself properly if I am lacking solid pipe. i'd guess the wet return is about 10-15yrs old and is currently galvanized I think...i may get lucky .. will report.1-pipe Homeowner - Queens, NYC
my NEW system pics | my OLD system pics0 -
pipe threaders are cheapish
Sorry, I can't answer your question, but you can buy a hand pipe threader for less than $100. I bought a chinese one for 1/4-inch to 1-1/4-inch sizes. It's not the greatest quality, but it's still going strong a dozen or so uses later. Anyway, just thought you might have an easier time cutting and threading the existing pipe rather than trying to break loose an old fitting.
These guys have something that may work.
[url=http://www.arizonatools.com/tools/pipe-threaders/detail/WIS22PT3/?utm_source=googlebase&utm_medium=organic&utm_campaign=productfeeds]http://www.arizonatools.com/tools/pipe-threaders/detail/WIS22PT3/?utm_source=googlebase&utm_medium=organic&utm_campaign=productfeeds0 -
hey thanks!
Thanks for that .. i had been looking at this .. or trying to rent one .. but I think I may get the one you posted .. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=959551-pipe Homeowner - Queens, NYC
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
