Our master bedroom vent clangs when the hot air heat comes on
guppy62
Member Posts: 3
in Gas Heating
The master bedroom vent clangs when the heat comes on. It goes on for quite a while and will eventually stop; for a while. When the heat turns off the clang is back. The basement is finished so I do not have access to the heat ducts. PLEASE HELP! I am a light sleeper and wake up every time this happens.
TIA,
Kim
TIA,
Kim
clanging register
can you clarify the type of heating system you have--forced air with ducts/registers--hot water heat with radiators--steam heat--also with radiators?--nbc0 -
forced air
I have a forced air heater. House was built 12 years ago.0 -
ducts and registers
I have ducts and registers. I have moved the damper back and forth in the duct as well. This is not loose or shaking. I can hold it steady and still have the ping.0 -
It sounds like you have
expansion and contraction noises in the duct work because you say it happens when the heat comes on (expansion) and it happens when it shuts off (contraction). I recommend you have an HVAC contractor check it out as there are things that can be done to stop this from happeneing. The lack of acess to the duct work may present a problem. Is this happening anywhere else in the house?0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
