VENTS TO REPLACE RADIATOR VALVE
BARGO
Member Posts: 11
i HAVE 3 RADIATORS ON THE MAIN FLOOR THAT DO NOT HEAT WELL AND OF COURSE THAT IS WHERE THE THERMOSTAT IS. i SAW ON PAGE 118 OD DAN'S BOOK A GUY THAT VENTED AT THE RADIATOR VALVE. DOES SOMEONE MAKE OR SELL A PRODUCT FOR THIS/
BARGO
BARGO
Vents
These are just regular`pipe fittings and vents. If three radiators aren't working well in the same area, you might want to take a look at the main venting on the main that supplies them steam. The vents for the radiator are available in different sizes and so you might want to try a larger capacity vent. It is also possible to use two vents on a radiator thought you can run into problems with this. Do you have a one pipe or two pipe system?
- Rod0 -
main in view just put in new vent
I have had about 5 new vents put in in the last 5 years. not sure where to put another. I guess I could tap the pipe from those radiators to try and find where to put another vent. I have a single pipe system. I figured it would be easier to relocate the turn valve (as in Dan's book) and vent at the radiator. I do not have any vents on these radiators because they are so slow. everybody is cold on the main floor and warm everywhere else,
Bargo0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
