Family Daycare Provider
Janetann
Member Posts: 1
I was given this website by the technical dept at Weil-McLain, the manufacturer of a gas burner I recently had installed in my home. I have had some trouble with the thermostats regulating the heat and at one time the steam heat zone in my house was 93 degrees! PSE&G was here today and identified several problems with the installation of the equipment, one being the Hartfood loop being too high. I am searching for a heating person who specializes in steam systems to correct the installation. I live in Central New Jersey, the Elizabeth area. The Weil-McLain contact told me the "good guys" hang out at this website. Please help. I can't afford the gas being used to over heat my house. Thank you.
FAP
Go to the top of the page and click on Find A Professional. Put in your zip code and a 30 mile radius. You should find a few to click on and look at.0 -
Book on Steam Heating for the Homeowner.
As was mentioned use Find a Professional above. If you don't have a steam pro listed locally to you I'd still give them a call as they maybe able to refer you to someone in your area.
I'd also suggest you might want to get a book offered on this site called " We Got Steam Heat ! " It's easy reading.(not a technical book) humorous,with lots of pictures and illustrations and written for the homeowner. In an evening or two you'll know a lot more about steam heating. http://www.heatinghelp.com/products/Books/5/61/We-Got-Steam-Heat-A-Homeowners-Guide-to-Peaceful-Coexistence0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
