Mystery Hoffman Valve
L'town Radiant_2
Member Posts: 39
I have a Hoffman valve that my rep doesn't seem to be able to help me with. The valve says that it is a No. 11 Vacuum valve. I figure this is either a vacuum breaker or a main vent on a vacuum steam system. I know that this is on a low pressure steam system, but I wasn't on site to see where it was installed. Can anyone confirm or clarify?
A warm floor warms my heart!
Here you go.
http://www.heatinghelp.com/files/articles/1306/310.pdf
It's in the site's Library. It's a main vacuum vent for a vapor-vacuum steam system.
It pays to wander off the Wall.Retired and loving it.0 -
here you go
According to Gill and Pajek's sheets, it's a Hoffman #11 main vent rated at 2.410 CFM at 2 oz pressure. Love that book.
http://www.heatinghelp.com/products/Books/5/146/Balancing-Steam-Systems-Using-a-Vent-Capacity-Chart-by-Gerry-Gill-and-Steve-Pajek0 -
That vent was used
on the original type of Differential Loop. If it needs replacing, a couple Gorton #2 vents would work.All Steamed Up, Inc.
Consulting0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
