Arco Convector Ratings
ChrisTow
Member Posts: 4
Does anyone know where I can find ratings for American Standard "Arco Cast Iron Convectors for concealed installation" from the 1940's? I found a catalog page for them in the library, but the dimensions and ratings aren't included. Thanks
Chris
Can anyone tell me if they're included in Dan's EDR - Rating for Every Darn Radiator book?
Chris
I am working on getting the manuel to Dan for posting
this help?Cost is what you spend , value is what you get.
cell # 413-841-6726
one more try
It pays to read the file before attaching.Cost is what you spend , value is what you get.
cell # 413-841-6726
that's it
perfect. thanks0 -
Thank you very much.
Thank you for posting this. I did not find this info in Dan's book and the approximation I was using from a similar setup that was in the book was about 75% over in EDR sq. ft. Since I have three Arco's it really inflated my figure. Your post of those pages was right when I needed it. Much appreciated.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
