Sheesh,,,,
Navigation sure is rough!!!I wonder if that`s why the "old timers" are staying way?
I am 71, but I doubt I qualify as an old-timer.
Since I an not a pro, I can hardly consider myself an old timer.
But I guess I am old enough to be one, even though I lack experience in this field.
I think if you play with this site for a few days you will get the hang of it.
I use FireFox to read this in RSS (most of the time) and if I do that, I get the top new posts in a menu and all I have to do is click on one to get where it is.0 -
I use
FF too,,, but that doesn`t make-it any easier for me!!!!0 -
Define "rough"
I don't see any problems with navigation. Yes, it's way different than what it was, and it does take some getting used to, but every site I visit is different.
If it was the same as before or the same as every other site, that would make for a very boring heatinghelp.com experience. Dan gets' two thumbs up from me.
If you would explain what problems you're having, I'm sure there are many that would jump in to help you out.0 -
"rough"
Way different for sure!!
This "converting file-type" stuff is giving me probs "big time"!0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
