pet peeves
That pass for serial numbers.
AJ8723...72841(one or "eye"... we'll never tell U) a symbol "the Artist formally known as Prince"...66690 (oh or zero?)
Tech Support: "Uh, that's not coming up on my screen..."
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Supply House Rick
    Supply House Rick Member Posts: 1,404
    pet peeves
    why cannot mfg.s make a legible serial/model no. plate? why wouldn't they know that a lightly pressed in number on shiny aluminum is ALWAYS going to be illegible...and their tech support always asks' "what model no. are you calling about?" hoffman adjustable vents are also unreadable as far as the "F" and "S" not to mention the arrow.....ahhr!
    any other gripes out there?--nbc
  • TJ_5
    TJ_5 Member Posts: 71
    pet peeves
    Tech support that doesn't
  • What about
    serial numbers without a date code in them ? Quickest way to find out if the unit is under warantee - and many manufacturer's don't do this simple thing .
    Yep , it's too easy to wipe away the numbers on a plate if they're inked on . Everything should be stamped in my opinion .
