diy hot water heater
the pump is bronze . The fresh water will kill any cast iron pump over time . You'll have to rewire the surface mount aquastat(s) also .
There's a few resources online with schematics to pipe the tank . Let us know if you need some links .
Thinking of using the hot water coil in my Wiel Mclain oilfired boiler to heat water and store it in an electric hot water heater by using a pump to circulate it. I've heard of people doing this to get less variation in their hot water when taking a shower. Plan on using a 40 or 50 gal heater with a Taco pump. Any info or comments would be welcome.0 -
Links and schematics would be helpful. If you could send I will be thankful. Thanks for the reply.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
