Outdoor Wood Boiler
Steve Ebels_3
Member Posts: 1,291
Would be your state's website. There should be a section dealing with codes and more than likely a section specific to OWB's. Many states and localities in the Northeast are placing restrictions on how/where they can be installed and some are banning them outright. The generally accepted standard now is a gasification type boiler that emits far less pollution than a regular OWB.
Good Luck! Alternative energy is the future.
Outdoor Wood Boiler Requirements
What (if any) are the Mass State requirements for a resident to have an outdoor wood boiler for home heating?0 -
You need
You need a building permit. It has to be inspected by the building inspector. There are certain licenses that cover the installer. I do oil and it doesn't cover me for solid fuel so I am not licensed for these units. Your local building inspector should be able to tell you what license your installer needs.
Leo0 -
written info
Leo, thank you for the reply.
Do you know where I can find written information on outdoor wood boilers?0 -
See..
My reply about "wood boiler piping" I do not consider outside wood boilers money well spent.
Rich Kontny0 -
See..
Rich double click (senior moment)0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
