Source for 3/8\" Long Flare Nut
Kool Rod
Member Posts: 175
Hi Erich-
Try either a company that sells hydraulic fittings though probably the easiest is to just get it from Mc Master Carr
http://www.mcmaster.com/#
Look under "Flared tube fittings" and you should be able to find what you want. McMaster Carr are great to work with and will get your part shipped out to you the same day. While you have to pay UPS charges though I have found that's cheaper/easier than having to run about place to place looking for an odd ball part.
- Rod
- Rod
Does anyone know of a source for 3/8" US made Long Flare Nut. Everybody has the Short 3/8" Flare Nut in stock.0 -
commercial refrigeration supply
commercial refrigeration supply----in nyc we use adco0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
