Testing Hoffman A-1 vent
bob young
bob young Member Posts: 2,177
BLOW THROUGH IT UPRIGHT . THEN UPSIDE DOWN. [ IT SHOULD LOCK ]
  • Jeff_133
    Jeff_133 Member Posts: 36
    Testing Hoffman A-1 vents
    Is there a way to test a Hoffman A-1 vent for proper functionality, other than installing it in a radiator and waiting for the system to cycle?
  • Jeff_133
    your test
    do you mean it should be locked once you turn it upright again?
  • bob young
    up=air ----down=none
    Upright you can blow thru it. inverted , the float drops & it closes. can't blow thru it. fairly simple mode
  • Jeff_133
    ok, got it
    not trying to make this more difficult than it is... but... one thing i noticed is i had a Hoffman vent that shut when it warmed up, but then did not cycle on/off during the so-called "drop-away" so the radiator never was getting warm all the way through. i replaced the vent and that seemed to take care of the issue, but I need to test 15 more vents, and was wondering if there was a way to detect this, as it took me time to observe this...
  • bob young
    start blowing lol
  • Jeff_133
    that's pretty funny
  • lanceL
    lanceL Member Posts: 14
    testing rad vents
    I haven't done this but, having the same question, was thinking of extending my vent antler with a ball valve bushed to 1/8 to test them. Just my .02 Lance
  • The Boiler Dr.
    The Boiler Dr. Member Posts: 163
    I install a test station
    at all my boilers to facilitate testing. It is simply amazing how many vents get condemned when the problem is elsewhere.
  • Jeff_133
    interesting...
    where would be the best spot on the boiler to install a test valve?
  • bob young
    cut a tee into the header
  • The Boiler Dr.
    I take mine
    right off the top cross tee on the low water cut off.
