closely spaced tees
john_83
Member Posts: 76
No as long as you dont exceed you spread.
closely spaced tees
i have a question pertaining to closely spaced tees for hydronic heating, if you would be so kind to answer. does it matter if the two tees are positioned from the main in two different directions. for example one from the left the other from the right to the main?0 -
That will work fine, Dmitri.
What is more critical is having 7-8 straight pipe diameters upstream and downstream so that other fittings and elbows do not interfere with the flow.
Take a look at Taco Load Match fittings- tappings on one side but you can peel off in two directions with street elbows."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
