Quite unit heaters
Keith_8
Member Posts: 399
Any of you guys have any experience with quite unit heaters?
I did a survey of an indoor tennis court that has multiple problems with their heating system.
One of the problems is the warm air furnaces lack of dependability and the blower noise they make is distracting to the players.
I suggested unit heaters and a boiler but the owner has concerns about noise from the unit heaters.
Any suggestions?
Keith
Any suggestions?
Keith
Becan morris is quiet type unit heater...
PSU units from Smith Environmental. Whisper quite.
Ken
They're not talking "cabinet puppy's" here!
Jed
p.s. edit Sorry, Ken. I was thinking Quiet One's0 -
Tennis Court
Have you looked at a "sock system"? Or AHU w/constant fan & air exchange?0 -
In addition
In addition to finding heaters that are as quiet as possible, you may want to investigate some acoustical material of some sort. My guess is that a building containing an indoor tennis court is going to be mostly hard surfaces which reflect any and all sound many times before the waves dissipate. Some acoustic material hung in strategic locations may help more than finding a quiet heat source.0 -
Forget Air
Why not use overhead low-intensity gas-fired radiant? Ooooh.
Just buy the ball guards. (For the heaters -unless you are playing with Olaf. He dere got one mean low serve, you bet!)
Co-Ray-Vac, Reverb-A-Ray (Detroit Radiant) and others that do not have a Morse-Code Syntax...
If an air system, the sock system Ed mentioned makes a lot of sense. Just make sure that the returns are LOW and heavy-duty. You will not destratify effectively unless you do that. You also may want to put in destratification fans.0 -
tennis court heat
> radiant? Ooooh.
> (For the _i_heaters_/i_ -unless you are playing
> bet!)
> Syntax...
> fans.
low intensity radiant is a great way to heat them. Quiet and comfortable.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
