Concentric vent expansion noise!
Mike T., Swampeast MO
Member Posts: 6,928
Do the joints use gaskets?
If so, how about some petroleum jelly or silicon-based lubricant.
Hey Guys
I have a concentric vent that has quite a few (10-15) expansion poping noises everytime it fires up. Is this common with concentric vents? What may be the best way to eliminate this? Thanks.0 -
I have much less problems
I had one or two noises for a while that then largly went away. I note that I have a longer run than normal (approaching the maximum effective run length) complete with 3 90 deg elbows instead of just 1 90 deg elbows for the simpler systems.
Perry0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 49 Industry Classes
