Reduced Water Pressure in Shower
Bill A.
Member Posts: 1
I have a weil-mclain tankless hot water system which both heats (steam) and provides domestic hot water to the second floor apartment of a two family home. recently the tenant has identified a reduction in water pressure in the shower - not so in the kitchen or bathroom sinks though. Water provided remains hot enough, simply pressure is the issue.
Can anyone tell me what might be the problem/tell me what steps to use to diagnose?
Thanks
Bill
Thanks
Bill
First
I would remove the shower head and make sure it's not clogged by calcium deposits. Is there an anti-scald valve on the shower? This might need to be cleaned, adjusted, or replaced.0 -
check to see if there might be a restrictor installed in the shower head.also tale the time to check the shutoff valves for washer troubles.0
- 86.8K THE MAIN WALL
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
