Gordon-Piatt air switch
RonWHC
RonWHC Member Posts: 232
replacement for G/P is Cleveland AFS. You'll need to tap in 2 - 1/4" connections to the burner housing & run tubing to the low & hi side of the switch.
  • GenoC
    GenoC Member Posts: 8
    Looking for an air proofing switch. It mounts on the back of the control box, old mercury style, directly into air chamber. Anybody know where one can be found. Unless if the diaphram conversions are cheaper than here in Minneapolis, the owner wants to keep resetting the control every couple of days. Again, in advance, thank you for your help. Can post burner info later if needed, just don't have info on me at moment.
  • ttekushan_3
    ttekushan_3 Member Posts: 963
    try these guys
    I have no association with them. Didn't look too closely, but they have the conversion for a good price given the kind of equipment you are dealing with.
    acme control services
    Not to be confused with this company with a notorious print catalog:
    Terry T
