Munchkin 925 controller password
Guy_6
Member Posts: 450
Be very careful with what you change. The flame proving time is NOT an aspect of the programming that you can change, as it is a safety factor. At any fan speed. You CAN change the method of operation:The default is firing low and working up the 6 steps to high or the modulation point (whichever comes first). The change that you can make is firing and ramping immediately to high fire, then modulating down from there as necessary
MUNCHKIN 925 CONTROLER PASSWORD
Hi does anyone have the password to reprogram the 925 control board. We had the password but can not find it now.... Want to change the 20 sec flame proving on high fire. If anyone out there can lend a hand. Thanks for your time.0 -
The default password is already in your message above, but if you changed it, that's a problem.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
